D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Posted on Jan 04, 2010
I have a D-Link WBR 1310 and i'm having issues with it. It started working fine but i leave for 3 months and all of a sudden it no longer works, Any help?
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
3561
Points
36
If your D-Link WBR 1310 is still under warranty, i suggest u to go to the place where u bought it... They know how to find the problems on your device... At least, if something needs to be replaced, they will replace it without any cost... simple right???
3answers
I lost my d-link model dir-615 disc. can I download it for free?
The Dlink site has all the drivers for each of their products. See the following link for yours.
http://www.dlink.com/products/?pid=WBR-1310
You will have to see what version of the hardware you have.
Have dlink router 1310 when switched over to jumpstart no longer usable
There are multiple versions of both of your routers, you can click on your version and try there tech info from there. If you have no luck, just post the right versions here and I'll see what I can do for you.
There are multiple revisions of the WBR-1310, each with revision specific drivers, firmware, installation guides, and other resources.
There are multiple revisions of the WBR-2310, each with revision specific drivers, firmware, installation guides, and other resources.
Go to there support page and click on your model.
http://www.dlink.com/products/default.aspx?pid=WBR-2310&tab=3
1helpful
Everything on my D-Link WBR 1310 has been working fine for over a year. All of a sudden, it is not broadcasting on wireless. All the green icons are lite up except (((. I've powered off and pressed reset,...
Its frustrating when things go bad just past the warranty. However there is one thing you can try first.Try to find an update for the router's firmware. Then go into the router's administration, click on update firmware and browse for the firmware file you have downloaded. This will update the firmware and automatically restart the router. See if it fixes the issue. If it does not I'm afraid that you will have to get a new router.
Hopefully it works,
Sai.
What is the default password for the WBR 1310 wireless Router?
For the D-Link WR-1310, the following are the default login credentials:
username: admin
password: (none). Just leave it blank.
I install my Dlink router WBR-1310 and now i want to reset and reinstall again.But i don't know how i can move from control panel Because when i reset it doesn't work.
There is a small pin size hole on the back panel. Take a toothpick or some small pointed thing to stick down this hole. Hold the pointer down for 10 seconds or longer to allow a complete reset.
3answers
WBR-1310. No admin logon, only f/w upgrade page
Download firmware from site
http://www.dlink.com/products/?tab=1&pid=WBR-1310&rev=WBR-1310
DLink states the login issue has been fixed with firmware v1.04 3/28/07
Remember to get the right one for your unit model. You must connect a RJ45 cable to the router and computer you have downloaded the firmware to and remember which directory it's in. When it asks for the firmware put in the target location (c:\my documents\xxxxx) of the firmware file. Good luck.
Router won't connect w/desktop
yeah well..since if u had XP you will not be having that problem..but since it is vista..you ll have to ask your internet's customer care..to reset modem through which your wireless router gets the signal..and then try it should work for sure..ok
D-link wbr-1310
i think what you need to do is to login to the router by typing in its ip address like 192.168.0.1 all you have to do is hook up your computer via ethernet cable to the router then start configuring the router. you don't have to install any drivers for routers
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
