Flashing on oven F54 shut off oven at circit breaker and when put back on still flashes F54 with the beeping sound
HI. This code is an indication of a shorted upper door latch circuit. This could have be caused by a malfunctioning relay board.
The necessary actions are to gain access to the upper door latch assembly, and test the circuit with a meter. Use the procedure below.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing.
NOTE_ If the upper door latch switch passes the test, simply replace the relay board.
