Speed Queen ATS90AWN Front Load Washer Logo
Anonymous Posted on Dec 28, 2009
SWFT71 Speed Queen Model # SWFT71Wn Installed new door latch and it won't let door release after running its cycle. Replaced all electrical plugs to switch and still same problem. Any other suggestions.
Anonymous
Level 2:
  • Expert 84 Answers
  • Posted on Jan 12, 2010
Anonymous
Expert
Level 2:
Answers
84
Questions
Helped
21436
Points
156
Did you replace the striker on the door, or the door lock mechanism?
Try adjusting the striker on door.
Speed queen washing machine model number awne82sp11two1 stuck on cycle
If your Speed Queen washing machine is stuck on a cycle, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
  1. Check the power supply and make sure that the washing machine is properly plugged in and receiving power.
  2. Check the fuse or circuit breaker to make sure that the washing machine is not tripping any electrical circuits.
  3. Make sure that the washing machine is not paused or paused on a cycle that is longer than usual. If the machine is paused, simply press the start button to resume the cycle.
  4. Make sure that the washing machine door is properly closed and latched. If the door is not properly closed, the machine may not start or may get stuck on a cycle.
Can you eliminate Error codes on a Speed Queen front load washer, AFNE9BSP113TN01
Bad connection to power of the fill switch or not airtight to the hose on it.
E:FL - Fill Error - Pressure switch fails to open in 30 minutes in any fill agitate cycle.
Speed Queen Fault Codes - PartSelect
https://www.partselect.com > JustForFun > Speed-Queen-F...
1helpful
Speed Queen LTS90AWN will not go into spin cycle I replaced the door switch and door lock switches.
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Speed Queen Front Load Coin operated # SWFT71.. The coin changer keeps getting stuck. Any ideas on how to resolve this?? How do I remove the coin changer from inside the machine??
I have not fixed any of these front loaders for a while, but the top cover should come off (usually with a key), which will give you access to the coin mechanism and timer. There you usually need a 5/16 wrench or a flat screwdriver to remove the screw at the top of the mechanism.
4helpful
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
2answers
SWFT71 washer door not opening
Two things to try. First cycle through the cycles a few times and see if it will unlock. If that doesn't work, then unplug the machine for a couple of minutes and try cycling through again. If that still doesn't work, then try pounding a little on the machine and rocking it to try and loosen the lock. If that still fails, then you will need to remove the outer paneling of the machine and get to the door/lock from the inside of the machine and get it unlocked. If you are uncomfortable with any of these suggestions, then let someone who is mechanically and electrically inclined work on the unit. Let me know how this works out for you. Benjamin
Top Speed Queen Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
