PC will not power up. No fans, lights, anything. Power supply checks OK with tester and PSU fan runs OK on tester. Reversed reset and power on switches, but no help. Shorted the ''power on'' pins on mobo in case both switches were bad, but no help. Removed everything (incl. mouse, keyboard, & monitor) but video card and 1 stick of RAM. Unplugged and reseated both power cables on mobo. Nothing turns on - power supply fan, processor fan, no boot beeps. Suggestions?
Did not try diff AC power cord or AC outlet as they worked OK when using tester on power supply (the type that lets you unplug the PSU output power cord from mobo and plug into tester - tester shorts grn/black pins and lights come on when output voltage is within specs).
