20 Most Recent
Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop Questions & Answers
Bluetooth keyboard and mouse not working with computer
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
How to clean memory in dell 531s
If you think you're having a memory problem, you have these options:
1. Re-seat the memory chips and make sure they're in the socket correctly.
2. Go to
www.Dell.com/support. They have diagnostics that will test Memory and all systems in your PC and show you what might be wrong.
3. You can run a memory Clean or defragmentation yourself. Go to Start, then Computer, then right click the C drive and select "Properties" then look for "Clean Memory" and/or "Tools" to do the "defrag".
Hope this helps.
How do I know if my boot ste up is correct
If your PC doesn't boot up using the hard drive, you can check that by looking for the F2 or F12 displayed on the screen during boot up. Then start pressing F2 or F12 quickly to get setup.
In setup follow the directions and set your "boot device" to "hard drive"
Hope this is what you needed.
Hp officejet j3640 not working on windows vista. I
first check your is working or not
then open control panel - administrative tools - services - printer spooler services - double click the services - click stop button - next click start button - choose automatic then give the print if not coming connect other pc to ur printer check printer
Booting up
Yes, I would check all connectors and remove all devices to the bare bones and see if it boots up. Then re-install cards one at a time to see if you can isolate the problem to a specific card or device.
CD tray broken
DVD writers are sold as complete unit, they relatively inexpensive. You can fit them yourself, with nothing more than a screw driver, if you are comfortable doing this. Most computer shops will carry stock and be happy to fit the new equipment, although there may be a charge for this.
Inspiron 531s diskette error
Power on computer and enter
the set up (BIOS) menu by tapping the F2 key.Under DRIVES, you must disable floppy in
set up (BIOS) menu.
Why does my icon Page take long to download??
The reason why that happens is because after sleep mode the machine take a little while to start running all the back ground processes so your page will wait until all those processes start running then the machine will do your assignment.
KJR
Inspiron 531 / vista restore
Test all power and data leads that attach to your hard drive IDE,SATA the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios. Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system. Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd\dvd. Hope this helps.
I get a connection error every time i open internet explorer
create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the general tab tick in the box to delete temporary files history cookies and saved passwords
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
hope this helps
My dell inspiron 531 PC just keeps beeping and
The beeping is called a beep code, you may be able to check the connections on the inside but only if you know what you're doing. You will most likely have to take it in the be serviced.
My computer tells me that if my wireless adaptor
Try plugging the wireless adapter into one of the usb slots on the back of the computer. If it still shows that message, I wouldn't worry. The difference in speed is negligible at best.
hope this helps
