The way to solve the problem is as follows:
1. Goto the My Stuff Icon and select the "My images" Icon.
2. Select a Photo to open it.
3. Click the drop the drop down menu (▤), and click rename.
4. Type in a name then .jpg and save.
5. Then "send" it to bluetooth.
Voila! Good luck everyone.
Same oribem as Sbashby - unable to print, though it can see the Pogo printer, it will connect but then immediately disconnects.
r14sharpe and DrMacFix nailed it - dunno how you discovered that !
So like he says the filename contains underscores ( _ ) and dots ( . ) as well as [ ] and some other characters in the photo filename.
An example would be renaming the file P180409_20.02_[02] to
P180409200202 which then prints fine over bluetooth on the Pogo.
As long as you use the Rename option from "My Stuff" (the top left menu icon), you can remove those, leaving only letters and numbers.
It's not necessary to add '.jpg' though as DrMacFix stated, so that's one step saved (the file already ends in .jpg so its redundant)
The photo file name saved on the lg501 has symbols in take these out and it will work
Cannot print picture on my POGO printer from my LG501 phone it just keeps disconneting i am paired ok
