Compaq Presario CQ60-220US PC Laptop Logo
Anonymous Posted on Dec 16, 2009
I wanted to put my pc like new but it didnt work now it wont turn on ...it gives me the esc..alt.del but it wont work
Anonymous
Level 2:
Scholar:
  • Expert 119 Answers
  • Posted on Dec 16, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
119
Questions
0
Helped
42474
Points
326
#1: Shut down your computer. You must first shut your computer down to initiate the factory restore.
#2: Start up your computer and as the computer logo appears (such as Dell or HP) hit "Ctrl>F11" simultaneously. This may be different for different machines, but the most common keys to hit are "Ctrl>F11." If this does not work, the F8 key has been said to work for certain machines.
#3: Select "Repair My Computer" from the list of menu options that appear and press "Enter."
#4: Choose the language settings that you would like and then click enter.
#5: Enter the administrator log in and password if it asks you for this information.
#6: Choose the factory reset option. This should reset your computer to the factory settings when you bought your machine.
http://www.supportdock.com/
1helpful
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Will only run on safe mode
Restart your computer
During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys
F10
Acer: - Ctrl +Alt +Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate
load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
How to exit safe mode
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails you might try some of these Acer: - Ctrl+Alt+Esc
The boot order was saved in the bios and now when i press f2 it wont let me in
Restart your computer During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys Acer: - Ctrl +Alt +Esc
My desktop 4210 is in paused mode how do i fix it
Step 1:
Award BIOS: (Del) or (Ctrl)(Alt)(Esc) Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
2answers
Access Toshiba BIOS
WHEN YOU FIRST TURN THE COMPUTER A LIST OF INSTUCTIONS WILL POP UP FOR 5-9
SECONDS, YOU NEED TO PAUSE THAT PAGE SO YOU CAN GET THE RIGHT ACCESS.
HERE ARE SOME DIFFERENT COMBINATIONS TO TRY.
DEL BEFORE TURNING ON HOLD THIS KEY DOWN UNTIL YOU HEAR THE BEEPING NOISE.
F2
F1 DURING BOOT
F10
RESET DEPRESS 2 TIMES
CTRL ALT ENTER
CTRL ALT ESC
IF NONE OF THESE DO NOT WORK THAN YOU NEED TO BUY THIS GUYS BOOK VER COVERS BOIS 2006 AND NEWER
I HAVE THE OLD ONE. VER 1997
THE BIOS COMPANION BY PHIL CROUCHER
Can not get laptop to enter bios
On many of the MPC laptops, the bios can be brought up at boot by pressing the F2 key. Generally, while booting, the screen will show you the button to push. Here are some more of the most used key combinations you can also try. On our mpc support site, there is no manual available yet for this model. Also, mpc laptops have the capability to lock out the bios at users request so many used models obtained cannot be changed. We'll have a new support site for mpc up this summer. Details at [email protected]
Most of the time during boot-up the key (combination) will be shown. If it is not, then you could try the following key combinations:
  • Del
  • F1
  • F2
  • F10
  • Ins
  • Esc
  • Ctrl+Alt+Esc
  • Ctrl+Alt+Enter
  • Ctrl+Alt+Ins after Ctrl+Alt+Del
  • Ctrl+Ins
  • Ctrl+Alt+S
  • Ctrl+S
  • Ctrl+Shift+Esc
  • Shift+Ctrl+Alt + Num Pad Del
  • Ctrl+Esc
  • Ctrl+Alt and +
Floppy drive
You're talking about My PC and device manager and I'm talking about Bios.
The BIOS (stands for Basic Input/Output System) is system software inside your computer that helps the computer start up, even before Windows does. It also contains key settings about what the computer has on board.
In newer computers, it exists on a special chip called CMOS (stands for Complementary Metal Oxide Semiconductor).
You can go into the BIOS to edit or change the technical information about key components of the computer like disk drives, keyboards, and display settings. It also keeps track of the date and time.
The BIOS can normally be accessed when you start your computer. You may see a reference to "Setup" when you turn your computer on. That’s your opportunity to get into the BIOS. It usually requires the push of a function key, such as F10, to get access to it. That "F" key varies between computers. Sometimes it’s not even one of the Function keys, but the ESC key or DEL key.
If a logo screen—like HP or Dell—is displayed during the start up process instead, then you may want to check with your computer maker for a command to turn off that screen and display the start up information, which is listed when a computer is powered on.
A partial list of BIOS access commands by brand is listed at the end of this article.
The BIOS also contains the boot-up sequence. Normally, computers are configured to boot from a hard drive.
Before you do anything to your BIOS, it’s always a good idea to record the original settings on a sheet of paper that can be kept in a safe place so you can reference it later if you need to reset it.
Here is a list of key sequences for various brand-name computers. If yours is not there, check with your manufacturer or watch for info flashed on-screen when your computer first starts, before Windows begins. It may say
"For setup hit..." That will be how to get into the BIOS on your machine.
ALR PC: (F2) or Ctrl+Alt+Esc
AST, Advantage, Award, Tandon: - Ctrl+Alt+Esc
Award BIOS: (Del) or Ctrl+Alt+Esc
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during boot up.
Aptiva - Press F1
IBM PS/2: Ctrl+Alt+Ins after Ctrl+Alt+Del
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or Ctrl+Alt+Esc
Phoenix BIOS: - Ctrl+Alt+S
Phoenix BIOS: - Ctrl+S
Phoenix BIOS: - Ctrl+Alt+Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl+Shift+Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift+Ctrl+Alt + Num Pad Del
Miscellaneous PC’s: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl+Alt+Ins
Let me know how it is going!
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
2answers
E-Machine T1100
What kind of BIOS version do you have?? here are some commands for the diverse kind of BIOS.
AMI (American Megatrends, Inc.) BIOS: DEL
Award™ BIOS: CTRL+ALT+ESC
Award BIOS: DEL
DTK® (Datatech Enterprises Co.) BIOS:P ESC
Phoenix™ BIOS: CTRL+ALT+ESC
Phoenix BIOS: CTRL+ALT+S
Phoenix BIOS: CTRL+ALT+INS
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
