20 Most Recent
MPC Computers TransPort T3000 Notebook Questions & Answers
Farmville will not load on the computer, it starts
Hello.
You have to clear history, cache and cookies.
There may be a bug/virus preventing you from loading the page.
Then try to
log-in.
If you still can't load farmville, try to load in on another
internet server.
Screen is flickering and goes
The problem you have can be either a software or a hardware problem.
It is a software problem if the cause of this problem is a video setting that your video card does not support. In this case you have to set the video card setting to a lower resolution
It can be either a hardware setting. If the software solution does not help maybe your video card is bad
How do i format my mpc transport t3000, i have no
While you will have a hard time finding OEM branded XP disks for MPC products (since the manufacturer is no longer in business) you can still use a retail copy of Windows to format the system (but it will require activation and a valid license key to do so.)
When the power comes, my l-top doesn't keep the
To determine if the battery is providing power to the CMOS, insert other changes to the bios besides time.
Like enable certain features and then power on, then turn off.
If the next time the date falters, go into the BIOS, and see if the changes you made are still there.
If they are, it is not your battery. If they are not, remove your battery, clean the terminals, (check the new battery is good) and reseat it.
michrophone may be related to the BIOS resetting. (solve one problem at a time)
Good luck. Don't forget to vote
My touchpad on my mpc transport t2200 is not
Also if your ac adapter(powercord)is bad, the touchpad/mouse sometimes will malfunction and become impossible to use or not work at all.Start with checking your ac adapter voltage or try another charger first.
Power does not stay
Remove the battery and unplug the power adapter. Plug back in the power adapter without the battery. If it runs without the battery and stays on then it is the battery that is the problem. If the computer still shuts down please contact the manufacturer or a local technician. -Ravi Shanghavi
