Ihave win vista in my pc please i want to setup win xp but
Ihave win vista in my pc please i want to setup win xp but i cant because Error Message: Setup did not find any hard disk drives installed in your system
Re: ihave win vista in my pc please i want to setup win...
Some systems can not be reverted back to windows xp because of drivers not being available. i have tried this before. u have to talk to manufacturer and ask can you do it.
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
you didn't post the make and model of the system, but on most modern systems, this error occurs when the Hard Drive Controller for the system doesn't have a native driver on the Windows install CD. So you need to load the driver during the install. In XP this is done via a Floppy Diskette (XP setup will not recognise a USB Drive) Vista you can install from just about any drive (USB Flash drive generally easiest)
you cant able to the vista sound to xp the driver the company will give you only vista driver cd so get the sound drive for xp - download more than 3 diffrent sound driver for your pci slot realtec audio from internet and install it and it may works.
The reason is, it only happens when you try to install Halo 2 on Windows XP.
The Game gets installed perfectly on Windows Vista
Because, I have installed and played the game on Windows Vista. But, when I de-graded my OS to Windows XP and tried to install the game. It gave me the same error message.
So, if your OS is Win XP then try install on Win Vista if you have it or on your friends PC.
But if you are already on Win Vista then please do let me know.
Also could please let me know whether your trying to Auto install the game
or you are manually trying to install the game by clicking Step.exe?
I would be glad to find some help for you in this regard.
I know this problem,
The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own
you need to load the driver (from a disk) so you may need to download it first.
I think this is the correct link
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en
extract the files and burn to a CD or Floppy then run win XP setup by booting from CD
you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen)
Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list)
you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal)
you want to remove all partitions before installing winXP (you can then make whatever partitions you wish)
Hope this helps
