Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
Posted on Dec 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installed a grohe k4 faucet and it will not retract back into neck of faucet. is the spring directional?
Rod Wallberg
Level 3:
  • Master 494 Answers
  • Posted on Feb 14, 2010
Rod Wallberg
Master
Level 3:
Answers
494
Questions
Helped
171959
Points
1170
Could be hung up if this has a weight to pull the hose back........
Need to tighten my ladylux
Grohe has a special tool that is used for installation that comes with the faucet. You have to remove the pullout spray and remove the curved neck of the faucet by pulling out. Insert the tool in the main body and tighten from above. Most plumbers will keep this tool when installing. I don't know if Grohe still uses the same system still today, but they did in the past.
3helpful
I have a Grohe Ladylux Plux kitchen faucet that was installed 5 years ago, and it is now loose. There isn't a way to tighten from underneath and the installation directions called for using a tool to...
you can pull the faucet arm off, the part right on top of the base , if my memory serves me correct you can tighten it with a creset wrench and the neck will pop right back on after
5helpful
2answers
Grohe sprayer faucet will not retract, spring around hose below.
check out the spring on the hose under the sink, sometimes they come loose on one end and they lose their spring back into the faucet
1helpful
I took off the head of my grohe ladylux pro kitchen faucet and when I disconnected the head, the mating thread retracted into the neck and now I can't get it back out again, the hose comes out but not the...
Take a drinking straw, crush one end and push it down the retracted neck, gently twist and pull and hopefully it will stick to the straw. If you need something stiffer use a disposal chop stick and place it in the end and try that. I carry thousands of dollars or tools and equipment on my trucks but sometimes its still best to improvise. Good Luck!
1helpful
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Grohe 32 071 K4 spewing water from single vale or tube under sink
There should be an o-ring on the mating surfaces of the hose and the faucet that my be missing.  It could also me that the big washer in side of the faucet (under the cartridge) has been shifted.
I doubt it is the cartridge itself, always try the cheap ideas first.
Top Grohe Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Grohe Home Expert? Answer questions, earn points and help others
