20 Most Recent
Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel Questions & Answers
Grohe hand held shower head stopped working
This is a simple fix. The tools you need are: cresent wrench. You want to remove the shower hear off of the pipe coming from the wall. On the inside of the end off the shower head there should be a small plastic disk remove it. It will have a series of holes this is called a water saver. The holes get stopped up with minreals take a tooth pick and clean them out. I see this all the time. If that does not work it will be in the valve
My grohe shower head falls to far so it points
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Shower fell apart or actually blew off under water pressure
Check water pressure valve if you are on city water it may be bad and allowing water to be more than it can take.
If this is the case you can make you up a gauge on a water hose connection to hook up to and outside faucet to get a pressure reading.
Low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin.
2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water.
3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Grohe veletto no enough flow on hot water
Step 1
Turn off the water to your faucet.
Step 2
Remove the handle to the faucet. Remove the small screw under the lever handle with an Allen wrench or Phillips head screwdriver, depending on what type of screw is present. Slide the handle back and off the faucet.
Step 3
Remove the temperature control knob, which is the round, dial-shaped fitting over the faucet cartridge. Put the manufacturer-supplied adapter on the cartridge. Line up the lever stop pin with the arrow symbol on the cartridge.
Step 4
Turn on the water and rotate the adapter to the left, or counter-clockwise, until the water temperature is at the level you want. Take note of the number to which the adapter points.
Step 5
Shut the faucet off by turning the adapter to closed and line up the limit stop dial with the number you noted previously.
Step 6
Assemble the faucet by replacing the temperature control knob and handle, then tighten the handle screw. Turn on the water and operate the faucet. If temperature is not set properly, repeat as necessary until you achieve the right setting.
5/13/2019 6:37:51 PM •
Grohe Home
Answered
on May 13, 2019
