Our mitusbishi will work fine and then randomly there will be a speaker pop and it will stop recognizing inputs. To fix it we have to turn it off and then turn it back on. It will happen anywhere from every 30 seconds to once an hour. I pushed menu and device and the error code it blined was 1-2
Code 12 indicates no error. Push the Menu and Device buttons after the TV has shut off to get the proper code, not after you unplug and plug it back.
It seems your set is not Mitsubishi WS-55819 so it will help if you can give the exact model.
ok I looked and you're right it's a ws-55613. The code is the one I got after it turned off though not before.
