I am unable to get a picture or sound when I am trying to record on my VCR. Please help me with this issue. thank you.
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on
which one you have it set to. If you are unsure, try both channels one
at a time) Press the VCR/DVD button so the display on the VCR says VCR
(not DVD). Now, you should be able to change the channel with your VCR
remote control. If not, you have a problem with your cables. Make sure
your cable from the wall goes to RF IN on your VCR. The RF Out on the
VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown
on the front of your VCR, then all you have to do is put in a tape,
select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the
TV/VCR button on the VCR remote, then use your TV remote to change
channels.
When you want to stop recording, press the stop button, put the TV back
onto channel 3 or 4 (depending on what you have it set to) and press
the TV/VCR button on your VCR again. From here you can rewind and view
your recording.
