Your keyboard MS 700 v2.0 needs a USB receiver to work. They are pert of set. You may also have a wireless mouse MS-700 that is also part of this set.
1. Do you have the receiver ? This has a USB connector that must plugged in to your PC's USB port
2. Are the batteries in your keyboard dead ? If so change them for fresh ones
Then proceed with the instructions in the Quick Start Guide which can be found from this webpage
Microsoft Hardware
Note the light on the receiver only flashes when you press the 'connect' button. At all other times it is normally out. There usually no lights on the keyboard. You should not need extra drivers as they part of the OS if you are using Windows XP or 7.
If you still have problems see
Your wireless mouse or keyboard does not respond or you receive The...
or search on the internet for our specific case
8.March.2015
SOURCE: Wireless mouse and keyboard not working
If you have got a USB receiver for the wireless keyboard and mouse, then the solution might be with the receiver. Normally we know that to play a USB thumb drive, we simply plug in and play. But some model of Acer computer require us to press the button on the thumb drive to activate it. The model I had (an Aspire model) set the press button same as the blicking light bulb. So (a) turn on computer, (b) plug in thumb drive receiver (c) press button on the drive, (d) press "contact" button on the mouse and keyboard. That works for me.
SOURCE: microsoft wireless mouse 700 works, slows, then stops
Seems like new batteries did the trick. Should start simple.
But I am not totally convinced. I will keep an eye on it.
SOURCE: microsoft wireless keyboard 700 v2.0 media keys
Media keys are reprogrammable. Use the CD that came with the keyboard and refer to the user manual for instructions.
You may also contact the tech support for your keyboard to assist you.
Have a great day!
SOURCE: microsoft wireless keyboard 700 v2.0 and mouse
hi
I Have purchased new microsoft wireless keyboard and mouse 700 v2.0 and it is not working can you help me it i s windows 7
SOURCE: Hi I have a Microsoft
Welcome to Fixya. Basically receivers are bundled with the mouse they have specific model of recievers. What i can suggest is you contact 1-877-696-7786 (Microsoft Store)f or a compatible model of nano reciever that will work witht the mouse and keyboard that you have so that you will not waste money on buying a reciever that will not work with your KBM.
Thanks for using Fixya.
