When i turn it on, it freezes and the power light on the bottom flashes. I also have to unplug it because none of the buttons on the actual tv even work, let alone the remote. the only thing on the screen are the words digital television on the bottom. please help
How many times does it flash? On many TVs the power light flashes a specific number of times to give a self diagnostic error code. This code can be looked up in the service manual and will aid in diagnosing the problem.How many times does it flash? On many TVs the power light flashes a specific number of times to give a self diagnostic error code. This code can be looked up in the service manual and will aid in diagnosing the problem.
You can't post conmments that contain an email address.
Probably power supply out on the main board. If you haven't before, buy a New TV and a UPS (battery backed up power strip) to protect your TV from power hits and Brown outs.
I found this on another website, most likely it is your power supply capacitors.
Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Initially, let us try a simple one; flick/snap with your finger nails any and all of the buttons on the front control panel of the TV unit. The ides is to unstuck any of the buttons. They maybe in a pressed position. Incidentally, any sudden change in the weather/temperature? Any rain lately? Condensation, dampness, humidity maybe playing with the rubber pads of the controls or with the electronics inside.
Alternately, you can try the hard reset; unplug from the mains for an extended period of time, say an hour or more.
Should none be corrective, pls post back the exact model number.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
