Trust WB-1400T Webcam Logo
Posted on Nov 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does this camera have a built in mic - or do I need a sperate mic to skype
Alan Spicer
Level 2:
Novelist:
  • Expert 127 Answers
  • Posted on Nov 28, 2009
Alan Spicer
Expert
Level 2:
Novelist:
Answers
127
Questions
Helped
43143
Points
364
I want to use Skype, but it always says that I need a USB headset. But I believe that my laptop has a built in mic.
Have you checked your device manager settings? You may need to 'enable' the built in mic if it has one. Skype has a test mic that works to help you hear yourself after this.
I can hear the other person im calling clear but they cannot hear me .I have checked the connections but still my built in Mic will not work
Your mic that is build into the camera might not have been selected.
For instance in Skype got to
Skype > Profile > Change Sounds > Audio settings > Mocrophone
Select from the pull down list the Microphone (8-bit USB Device).
1helpful
Please tell me why my built- in motion eye camera
you have to select the settings for skype...your camera is working but first you go into tools and settings to turn on the camera also mic(if u have)
I got an ACCER laptop and it has a built in web cam and mic but when i try to use it on skype it says device not found. Any help?
Go into Skype Options (Tools menu -> Options).
On the left panel, click on video/sound settings and select your camera from the list on the right.
1helpful
2answers
Skype shows "you microphone is really quiet"
Set up Audio example
Laptop x webcam/mic x Vista x Skype
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Start Skype.
On the Tools menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Set your speakers as default.
Select your webcam as the default microphone.
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
Select your webcam as the default.
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
I am new to Skype and have registered . I have a Webcam - Microsoft Life Cam VX-3000- and cannot get any sound , using the test facility . Any ideas ? Everything else seems to be working and I have checked...
If you have a laptop it will have a built-in Mic
If you have a webcam with a built in Mic you now have 2 on your computer and you are going to have to determine which one to use (make it 'default')
I would recommend using the webcam mic as default.
You do not say what your pc or OS is so here is the setup for
Laptop x Vista
Set up Audio
TEST SPEAKERS
Set required mic as default - click on mic font to highlight and click "Properties"
Restart computer
Configure to Skype
If you have an earlier OS than Vista you may have to access your hardware from the Control Panel
1helpful
I try to record a video with my web cam and it has no audio
Hi, first of all you need to make sure you have the microphone configured properly. If using the cams built in mic you need to make sure it works . If using XP Open the control panel and click the sounds and audio deviecs, click the voice tab, there you can select which Mic to use: the USB cam mic or another mic , then click test hardware. If you should see a mic playback test. if the level is there then the mic is working. next see if there is a mic level test/adjustment within the camera software, if using skype you also need to set it up and turn up the Mic level there too. you may need to add a mic, some USB cam built in mic aren't that good. you can buy a cheap mic and plug it into the pink jack.
hope this helps, please leave a 5 thumbs up if this helped
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Please help me
You need to check if the mic/s is working?
Are you certain the Logitech webcam has a built-in mic?
To check if the mic works go to Start - All programs - Accessories - Entertainment - Sound Recorder and test record your voice and play back to check, also try it with the laptop's built-in mic (if it has one) and the Logitech mic.
If both mics work then you have a choice of which one you can use in Skype, most likely the best one would be the Logitech one.
You need to configure your audio settings in Skype.
When you open Skype click on Tools - Options - Audio Settings and click on Select Microphone and select the microphone you are using and save the setting.
If you still have problems get back to me with all details and error messages.
2answers
Nx7010 mic problem
Did you check the sound settings for the mike?
Top Trust Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
john h
Are you a Trust Computer and Internet Expert? Answer questions, earn points and help others
