Not only missing codecs lead to QuickTime error 2048, many other factors also contribute to playback issues like that.
Here is the possible solution for you.
Guide: What If the File isn't Compatible with QuickTime Player?
When you see the error massage, it means something is wrong with your codec library or your video format is not compatible with your QuickTime player.
Since the reason for error 2048 QuickTime is not certain, there is more than one solution to cope with different situations you are in.
You can check on the article: How to fix error 2048 on your PC?
When i play it . it writes 2048 error
Error Code 2048 most commonly indicates that the device cannot acquire network resources. Error 2048 most commonly indicates one of the following situations:
To troubleshoot error 2048 With the phone on, remove the battery from the phone for one to two minutes. Reinsert the battery, and then attempt to log in again
