Open the GUI page of your router and configure DMZ
(Open command prompt on your system, Start>RUN>CMD, type ipconfig in the black window, check the default gateway, put the same address in the address bar of your internet browser like internet explore, it might ask you for username and password, which would be either 'admin' 'admin' or admin for username and 'pasword' for password)
Put your XBOX in DMZ and it should work
Or else simply go into advanced configuration in the Router GUI page and disable NAT
If you connect the computer directly to the modem, does it work? If that works then the modem is working. Now connect the computer to the router and the modem to the router. You will need to open the set up page of the router to check the settings of the router. You can set up the router without the CD also. It is very easy. Click Here for step by step instructions about how to set up the router
First verify that the printer is working by printing a configuration page from the printer itself. If it prints fine, uninstall and reinstall the printer with the latest driver from HP.
If the printer will not print an internal config page, replace the ink cartridges.
Try printing a configuration page to see if that comes out. If it does then you might have a print driver problem. Also try printiing a test page from the printer properties on that printer.
