This set needs a fluid change. Between the face of the picture tubes and projection lens there is a layer of coolant fluid. The fluid has turned a milky brown color and is degrading the picture. The tubes have to be removed in order to do this properly. I would suggest you contact a repair shop and have them check it out for you as this can be very complicated. Thanks for using fixya and I hope this helps you out.
My 52" philips tv has show redish double images and show shadow,any body can tell me the solution pls.
