20 Most Recent Philips 43P8341 43" Rear Projection Television Questions & Answers
3answers
I need service mode philips projection tv 43PP925
Hi
In this blog you can get TV service mode for Philips projection tv
5/11/2014 10:40:47 AM • Philips 43P8341... • Answered on May 11, 2014
2answers
Colour convergence on a projection TV
hello it sound like convergance chips may be the problem
shaun
1/10/2013 3:22:37 AM • Philips 43P8341... • Answered on Jan 10, 2013
The power board behind the buttens on inside is
www.tvrepairworld.com should have the keyboad your needing
8/1/2011 11:23:17 PM • Philips 43P8341... • Answered on Aug 01, 2011
Philips 47 inch rear projection
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
5/7/2011 9:54:23 PM • Philips 43P8341... • Answered on May 07, 2011
Our tv is very bright like the sun is always
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video or Bright Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
5/1/2011 9:31:24 PM • Philips 43P8341... • Answered on May 01, 2011
Philips 43p8341/37, The menu
The board you will be working on is the signal module. The signal module is the board on the floor of the TV. When you locate the RCA connections and the RF connectors on the back of the TV, you will know that you are where you should be. You will see two large silver fins, these fins are heat sinks and two ICs are attached to them. They will be STK-392-110, and both will need replaced. Also check and measure the 6.8 ohm 2 watt resistors next to these ICs just mentioned. Should be ten or eleven resistors. Replace as necessary. The next problem you describe is a halo effect on the screen and no menu on screen. You will need to replace contaminated fluid in one of the picture tubes. You will find three picture tubes, lit, they are red, green, and blue. I would suspect the blue has the contaminated fluid. You may look in the tubes and decide which one is cloudy. For more detailed instructions and photos, I would suggest you see the website, www.TvRepairKits.com. H ave your TV model number and symptoms near by. You can purchase a kit or kits to restore your TV. The instructions are very detailed along with photos as how to repair. Thanks for asking and show all hands of support!
3/30/2011 9:04:02 PM • Philips 43P8341... • Answered on Mar 30, 2011
2answers
Tv works but picture color
You have two problems, you have a convergence problem, the convergence board needs repair, and the other problem is the coolant needs change in the guns, (CRT's) and you are looking at 500 on repairs, you would be better off getting a new LCD.
3/2/2011 10:25:53 PM • Philips 43P8341... • Answered on Mar 02, 2011
From where i can get a ssb panel?
Here is some companys that I use for Parts .
Mats Electronics did have some ssb boards 1-800-628-1118
PTS rebuilts Boards 1-800-844-7871
Encompass Parts Distribution 1-800-638-3328
UED 1-800-648-6657
3/1/2011 3:22:56 PM • Philips 43P8341... • Answered on Mar 01, 2011
Pwoer blanking in and
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps kits can be bought online ,are inexpensive and, if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
12/14/2010 9:48:08 PM • Philips 43P8341... • Answered on Dec 14, 2010
How can i re callibrate my colours. my bulbs are
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
12/4/2010 12:11:13 AM • Philips 43P8341... • Answered on Dec 04, 2010
Our tv has a blur
Convergence ICs will be big black ICs will have PN# on them ,example STK392-110
Mats has them 1-800-628-1118
Encompass Parts Distribution might have whole board 1-800-638-3328
10/21/2010 10:31:59 AM • Philips 43P8341... • Answered on Oct 21, 2010
Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
9/24/2010 4:43:30 AM • Philips 43P8341... • Answered on Sep 24, 2010
To much blue on top half of screen
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadow pictures or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must change to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
9/14/2010 7:29:03 PM • Philips 43P8341... • Answered on Sep 14, 2010
Philips 46 in rear projection tv has too much
this models have coolent issues. I would tke off the front screen very carefully , as it may seperate , get a friend . Do not scrach the screen. then look down inside the units CRT's (Cathode Ray Tube) and see if its cloudy or fuzzy looking . While there look at the blue tube as well. If its fuzzy replace the coolent.
7/8/2010 9:20:38 PM • Philips 43P8341... • Answered on Jul 08, 2010
Doubling images and shadow
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
7/3/2010 6:45:05 AM • Philips 43P8341... • Answered on Jul 03, 2010
Philips 43P8341 43" Rear Projection Television Logo
106 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips 47 inch rear projection
  • Televison & Video
