Gigabyte GA-7VKML Motherboard Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting three short beeps while booting - Gigabyte GA-7VKML Motherboard
Chris May
Level 2:
Novelist:
  • Expert 153 Answers
  • Posted on Nov 03, 2009
Chris May
Expert
Level 2:
Novelist:
Answers
153
Questions
0
Helped
77166
Points
391
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
John Snow
Level 3:
President:
  • Master 788 Answers
John Snow
Master
Level 3:
President:
Answers
788
Questions
Helped
212750
Points
2968
Here is a document for your issue.
http://www.computerhope.com/issues/ch000996.htm
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Anonymous
Level 1:
New Friend:
  • Contributor 46 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
46
Questions
0
Helped
16522
Points
85
Three short beepssugges memory instal failure try installing it properlu so that white or the black tabs locks up automatically if that doesnt work tried checkin ur system with one memory if not get mobo and the memory replaced
2 Related Answers
A
Anonymous
  • Posted on Oct 06, 2007
SOURCE: Wont boot
seems contagious mine did the same thing!not sure how helpful this will be but the bios handles the starting up part and if it's corrupt then that wont happen.If you can get the bios flash that you need onto a floppy then that might help at the moment I'm waiting for a new bios chip.Did you receive any errors at all ?awdflash.exe? insert disc etc ?
Anonymous
  • 134 Answers
  • Posted on Nov 13, 2007
SOURCE: Wont boot
I think there is a problem with the pin connection of the RAM. Remove the RAM again, then clean the pin with the contact cleaner spray then plug in again. do same thing with the CPU/processor if necessary. if you got One short beep when boot windows the problem haven't from hardware but on your system. try to run scandisk, disk cleanup, or press F8 while booting to go into "safe mode". Hope this be of some help/idea. Pls post back should you need additional information.
How to boot dell inspiron one 2020 when it only beeps
the number of beeps will tell you what the problem is the beeps are an error code here are the code list for your computer
Beep Code Description No Beeps No Power, Loose Card, or Short. 1 Short Beep Normal POST, computer is ok. 2 Short Beep POST error, review screen for error code. Continuous Beep No Power, Loose Card, or Short. Repeating Short Beep No Power, Loose Card, or Short. One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard or Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
2helpful
3answers
Pc won't boot, just beeping
firt well try the easiest solution.... did u take out the cmos battery on the board for a few minutes, put back in and try again. of course, unplug your computer before u do this. is there a beep pattern?, how many beeps...
2helpful
2answers
When i turn my computer on it has a long beep sound and then another long beep and wont quit... please help
Check your MEMORY MODULES . Try removing them, cleaning them with rubbing alcohol and the reinstalling them. Re-boot. That should work, ok?
My w3611 emachine froze and will not boot up. I get three beeps if I try. I am thinking it might be the processor, onboard graphics, or the bios.
Well if it's 3 short beeps then its a RAM failure. If its 1 long and two short then it;s a video monitor issue. 3 long beeps is a keyboard or keyboard card error.
2helpful
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
2helpful
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
14helpful
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
3helpful
2answers
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Wont boot
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
