Lens stuck, is common defective that need new lens unit replacement or just repairable. Causes
of a Lens Error: There are a number of ways with which a lens error can
be caused. Particulates might have managed to get into the mechanical
bits that allow the lens to retract, a purely physical interference with
the lens mechanism. If the camera was dropped, especially while the
lens was extended, there's a pretty good chance something might have
been knocked loose, such as the guide pins upon which the lens withdraws
and retracts.
How to Repair a Lens Error: As scary as a lens
error might seem, there are some easy fixes. Before trying any of them
out, however, first take a good long look at your camera warranty and
maybe have a chat with the company. If the lens error will be covered
under the terms of the warranty, go for it. Even some of the simple
fixes mentioned below might void the camera warranty. Frankly, however,
it's unlikely that a lens error will qualify for the warranty. Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Should be located on the block, passenger side, down low, and more at the front of the vehichle. It is a mechanical pump and bolted to the block with either 2 or 3 bolts, should have 2 or 3 steel lines cominng out of it.
You need to replace your CV ( constant velocity) joints. It's probably more cost effective to replace the axle halfshaft assemblies. This is not a repair I recommend for a novice, you may need to go to a pro.
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned. Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal. More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
