Washing machine kenmore 80 series top load washing machine, ten years old. When clothes were loaded and machine filled with water, it overflowed the top and flooded my floor. It did not go in to the spin cycle.
Kitchen Aid top Load Washer overfils going into the rinse cycle and just keeps filling. It does not alwawys do this, but certainly is a problem.unit is 4 years old
My problem is the same. overflowing during the rinse cycle. However, it only happens on occasion. Doesn't always happen with a big load. Where can I get a users manual that shows the parts and electric connections. I don't know where the fill valve is or the timer that sends the voltage to the fill valve.My problem is the same. overflowing during the rinse cycle. However, it only happens on occasion. Doesn't always happen with a big load. Where can I get a users manual that shows the parts and electric connections. I don't know where the fill valve is or the timer that sends the voltage to the fill valve.
Washer overfills at rinse cycle. Washer will fill to correct level at beginning of rinse cycle, the rinse cycle will take 30 minutes to complete. During the 30 minutes, it will sit idle for about 8 minutes and then agitate for 30 seconds, sit idle for 8 minutes and then agitate for 30 seconds. This goes on for about 30 minutes and then will attempt to fill, but the original water in the tub never drained, so it will overflow. I have had three repair persons out. The water level swith and air pressure hose were checked out. Now they think it could be the outer tub. I bought the washer in 2003.Washer overfills at rinse cycle. Washer will fill to correct level at beginning of rinse cycle, the rinse cycle will take 30 minutes to complete. During the 30 minutes, it will sit idle for about 8 minutes and then agitate for 30 seconds, sit idle for 8 minutes and then agitate for 30 seconds. This goes on for about 30 minutes and then will attempt to fill, but the original water in the tub never drained, so it will overflow. I have had three repair persons out. The water level swith and air pressure hose were checked out. Now they think it could be the outer tub. I bought the washer in 2003.
My washer overflows just after starting it. I can't get anything washed. Will this solution also fix my problem?My washer overflows just after starting it. I can't get anything washed. Will this solution also fix my problem?
AnonymousMar 20, 2014
the machine keeps filling with water it wont stopp and floods the floorthe machine keeps filling with water it wont stopp and floods the floor
Opening on top section of washing machine rustedOpening on top section of washing machine rusted
AnonymousMar 22, 2014
my top loading machine the rinse cycle water barely covers clothes and they are not rinsed properlymy top loading machine the rinse cycle water barely covers clothes and they are not rinsed properly
AnonymousMar 25, 2014
Will not spin dry?Will not spin dry?
My machine fills up with water then it don't wash, it just sits there and he number keeps going down but the clothes don't get washed.My machine fills up with water then it don't wash, it just sits there and he number keeps going down but the clothes don't get washed.
AnonymousMar 30, 2014
Hi, my washing machine will not stop filling with water, it runs. I did replace the switch as you said and that works fine now thanks, but the water keeps going even in spin please helpHi, my washing machine will not stop filling with water, it runs. I did replace the switch as you said and that works fine now thanks, but the water keeps going even in spin please help
machine is ten years old. spin cycles has gotten faster and louder. is it fixable or do I need a new one?machine is ten years old. spin cycles has gotten faster and louder. is it fixable or do I need a new one?
You can't post conmments that contain an email address.
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this: http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not. need to know if it agitates or drains and just wont spin. if it agitates but no spin or drain, then you have a bad lid switch. if it wont agitate or spin, but will drain, then you have a broken drive coupling.
The most common cause for this is the water mixing valve plunger sticking. the fix is to replace the mixing valve. Not so common is a defective water level pressure switch. Same fix, replace the switch. Really rare is a small leak in the tube from the tub to the pressure switch.
it has a little semi clear or black 1/4 of inch, long hose behind the control panel , who its attached one side to the level pressure switch and the other side to the tub.
culd be only this three options clogged ,bented or unnatached this hose to one of the sides tub or switch easy fix
Will not spin dry?
