Hi all. I have Thomson TG 585 Wireless Router (802.11g) connected to ADSL, and want to extend the signal by using D-Link DWL-2100AP AirPlusXtremeG. The question is: how can I manage that, and which mode should I use; the AP Repeater or the Access Point, and how?
any solution or suggestion is highly appreciated.
SOURCE: dwl 2100ap
This is the power cycle of death. No way to recover at this point. Send in for repair.
SOURCE: Connecting D-Link DWL 3200 AP as a wireless extender to D-Link DSL-2640T
could you able to solve.pse share
SOURCE: d-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
Dear Sir,
I have to worked on the DLINK DWL-2100AP AS POINT TO POINT with WDS with AP AND second one WDS Without AP
(1) First Install the Router ADSL &Wimax (and check the internet)
(2) Second you are install the DWL 2100AP WITH Mode WDS with AP and connect with the another WDS take the Mac Address in the WDS With AP and WDS With AP take the MAC Address in the WDS AND it connect the router with the Lan cable With the WDS With AP
(3) Third you are configure the WDS on the second DWL-2100AP
(4) You remember that both WDS With AP and WDS Same SSID like DLINK and other one same SSID like DLINK
(5) Be Care full you are use the Same WAP \WEP like that same and Same PASSWORD
(6) When you are enter the net work in the wireless then you see only one DLINK
(7) I try this one it s fine the working
(8) If any trouble then send the mail I help you Thanks [email protected]
Will this be used in a home or office? By how much are you looking to extend the signal? Please provide basic info on what your objective is, i.e. why you need to use this device, so I may better understand what your goal is and give you the best solution.
