Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Walkman NWZ-E436F will not connect to PC or charge. On connecting USB cable, Walkman logo display blinks or unit freezes on creating library ''clockface''
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Nov 04, 2009
Anonymous
Expert
Level 2:
Answers
65
Questions
0
Helped
18707
Points
123
First reset yours by the Back button;
If not solved;
Reset again by the button, the On the Computer by Fat32 Format, and then Copy the Initial Files that were on your MD when you Bought;
Good luck
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
11879
Points
24
If you are using a computer that is running Windows XP or Vista, you can try the advice in this article from Visualpawn.com
7helpful
3answers
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
3helpful
My Sony Walkman NWZ-E436F shuts off after creating the library
Hi I had the same problem and I finally figured it out.
First you will have to try to connect to the computer by pluggin it in and reseting once the computer recognizes it you should be able to look at the files.
If you are able to get the device to this point;
1. create a folder on you computer it could be in you desktop or document and name it something you would remember to go to. I named mine SONY.
2. copy all the folders from your WALKMAN to this folder;
3. delete all files from your WALKMAN there are some files it will not allow you to and just hit SKIP.
4. download the Firmware update (1.02) from the SONY Suport website: http://esupport.sony.com/US/perl/swu-list.pl?mdl=NWZE436F and select your computers operating system and download the file.
5. Once you download it run it and it should re-install all the necesary files back to you device.
6. Re-start the WALKMAN and it sould work just fine now you can go back and add your music files and photos, etc...
Good luck this worked perfectly for mine.
My sony walkman NWZ-E436F is charged but the will
It may be a loose ribbon cable going from battery compartment to main circuit board. THey have tendency to work loose.
1helpful
2answers
My sony walkman nwz-e436f was working fine and all the sudden its taking no charge from any usb ports
Check the connector of the USB Ports and Sony. Also it's internal battery require replacement.
Fully Charged Sony NWZ-E436F Doesn't Turn On
did anyone ever get back to you on this? I'm having the same problems.
4helpful
2answers
Sony nwz-e436f frozen on connecting screen
Hey! We've had a similar dilemma, and we solved it by connecting walkman to computer, then going into 'device manager' uninstalling the walkman, then remove it from usb port and re-connect it.
The computer will then 'recognize new hardware' and automatically re-install the walkman. Good as new!
Hope this helps!
1helpful
Sony NWZ-E436F will not connect to any PC
Your only solution, if you have tried all of those methods, is to replace the USB cable or find out from Sony if you still have a warranty on that product. The help page and Sony's phone number can be found here:
http://esupport.sony.com/US/perl/model-faq.pl?mdl=NWZE436F
2answers
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
