I am starting to get double pictures. I have a Philips big screen hdtv,60". Model# 60PP9202/17F
You may need to sinlpy adjust the convergence. Check your owners manuel for the proper way to access the convergence screen and follow it step by step. If this doesn't work, you may have a bad convergence chip. Here is my generic post for convergence.
You most likely have a convergence chip bad. In our shop, when we are working on projection TVs, we find that about 80% of the repairs we make are the same problem you are having. You need to replace the convergence chip ( there are 2 of the same chips on the convergence board, and I suggest you replace both ). If you are going to attempt the repair yourself you'll need to remember to use lots of heat sink grease so you don't have the same problem again. Also, try to get original parts, as there are times that the after-market ones don't work well. As a precaution, always remember to unplug the set from the wall before you do any work on the set. Good Luck
Ed
NC Electronic
Mills, Wyoming
Same thing but with red and blue shadows.
what's heat sink grease
