Expert
- Posted on Oct 18, 2009
Re: What is the trick to removing the leg from a 25 hp...
Its either up under the cowl near the bottom of the powerhead, or you might have to put the outboard in gear using the lever to drop the leg an extra inch, which would then expose a shift linkage holding nut in the gap above the leg connecting point.
1995 model lwer shift fork replacement
