I bought a motorola 1465 boost mobile phone and want to use it with my nextel phone but it asks for a special code when i put my nextel sim card in. Do you know the 8 digit subsidy code?
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security Code then :- This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (Security Code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone. They should provide you with instructions on how to enter this code into the phone. Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock Security Code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service. The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services.Use Google and search for "Security unlocking code” companies in your area. You can also try this WEB site :- http://www.mobileunlockguide.com/mobile-phone/ The IMEI number is unique the each mobile phone. The number is printed on the label under the battery. You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits
Remove the battery from the phone. Let it remain out of the phone for 10 minutes with the phone off. Replace the battery and turn the phone on.
This is a problem with the phone trying to read the SIM card after being in another phone. Be patient. It may take several minutes for the phone to read the SIM.
Boost Mobile runs on an IDEN network where tmobile runs on a GSM network. Unfortunately the boostmobile sim card will only work in nextel and boostmobile branded IDEN phones.
I called Boost support about the same issue and I was told that that particular phone and any other Ic series phone by motorola will not work with Boost Mobile. There was also a few other phones that will not work. Try calling thier support line and requesting the list of phones that won't work. Good luck.
if its locked with a passcode, when it asks for the code, hit the menu button, then enter all zeros, if it still does not work contact the site above for help
If this phone was originally a Boost phone, it is more then likley on the IDEN network, which is exclusive to Nextel/Boost. Once the new SIM from the company other then Nextel/Boost is put in the phone, it will ask for a special code- thus rendering the phone useless on the new network. IDEN is only used by Nextel/Boost and another company out of the South called southernlinc.
