I have a R40 with a DVD Burner. It was working fine up untill a few weeks ago. Now it only reads and burns CD'S. It will not read any DVD'S that I try. I have checked through the device manager and it says it is working correctly! Will it help if I try and find another driver for it?
Unable to read a CD-R or other recordable disc.DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support
The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
I recently installed a dvd writer for my neighbor. they used a top brand dvd-r / rw and never had any problem. but after the new install they had the same problem . after visiting the manufacturer's website we found that that certain brand of dvd were recommended. check the manufacturers site for dvd recommendations.
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
You need to try a commercial cd of any kind. You just want to see if it reads the cd. Then you want to try a dvd and see if it reads that. If it reads the cd but has trouble with the dvd then the heads are out of alignment. It might still write a cd but not be able to write a dvd as that require more accuracy and it doesn't have it anymore.
You may still be able to use the drive but you will have to replace it. The symptoms you describe are typical of the driver going out of alignment so I would say you are heading for replacement sooner or later.
These are not cost effective to repair anymore so all you can do is replace them. Unless you can get it replaced under warranty you can replace it for under $50 at any local computer store.
Is this an older drive? Possible that the drive is dying. I had this happen to me once. I ended up buying a new cd/dvd burner. The laser works different when reading verse burning, so it is possible that it is dead, but still working just enough to burn.
Just a suggestion, try to update your drivers.. If you have installed any third party cd burner just uninstalled it. after uninstalling, clean the registry via ccleaner, regcure, or any other 3rd party cleaner... then update your drivers... most of the 3rd party cd burner software are damaging your cd drivers...
