Dropped camera from height of 4' onto hardwood floor. Camera was in "off" position but turned on upon impact and lens extended. When tried to turn camera off immediately lens would not retract and viewing screen read "lens error". Now lens is in permanently extended position; can hear "whirring" noise when I try to turn off camera, but nothing changes. No image appears in viewing screen, but screen lights up. Anything can be done by me or do I have to take it to camera repair shop? Thanks. Matt
greatly appreciate suggestions but lens still stuck. Probably will have to buy new camera and try to prevent butterfingers. Mattgreatly appreciate suggestions but lens still stuck. Probably will have to buy new camera and try to prevent butterfingers. Matt
AnonymousMar 30, 2014
it turns on then screen in red letters lens error!it turns on then screen in red letters lens error!
You can't post conmments that contain an email address.
Before buying a new camera, recommend trying Fix #7 one more time using a little more force than you would have liked. You have little to lose at this point, the camera's broken. Look hard for any indication that one side of the lens is out of alignment (a larger gap on one side, a tilt of the lens, etc...).. If you see this indication, grasp the lens and try to straighten it by pushing or pulling to straighten. Use a wiggling motion, and listen for any click. Stop immediately if you hear this click and try the camera.
Good Luck!Before buying a new camera, recommend trying Fix #7 one more time using a little more force than you would have liked. You have little to lose at this point, the camera's broken. Look hard for any indication that one side of the lens is out of alignment (a larger gap on one side, a tilt of the lens, etc...).. If you see this indication, grasp the lens and try to straighten it by pushing or pulling to straighten. Use a wiggling motion, and listen for any click. Stop immediately if you hear this click and try the camera.
Good Luck!
you have stripped the lens gearing you will find that you need to have the lens gogs replaced a very expensive repair sir. it may be time to buy a new one
This one is almost assuredly headed for the repair shop, but you might try pulling on the lens a little bit. What has happened is that a gear tooth was skipped because of the impact on the lens, and it is probably cocked to one side. Look at the lens orientation carefully. You might be able to **** it back. Good luck.
This worked for my camera, Nikon Coolpix L10!! I'm so happy I didn't go out and buy another camera!!!
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Kathy
It worked. I just gently nudgged the extended(stuck) lens to one side by hand. (the side which had the gap.) There was a click sound and the lense housing fell back in place. Sweitched off and switched on again and the lense started working fine. thanks.
same problem
