you can reset the control board . to do this you must ground the # 15 terminal with a jumper wire to ground. this is usually the terminal next to the white & violet wire. check diagram.
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
I have done a bit of google research and this code probably means "Not Cooling" Due to a power interruption or sometimes if you do the initial cool down from 12v (instead of gas or AC). There are a couple of other causes but often all the unit needs is a reset. I found some details and instructions here but they don't specify an exact model. There were other details here but they refer to pages that are no longer available..
This should put you on the right track. Just do some more googleing if these details aren't specific enough.
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
