You could have a try on FoneDog Broken Android Data Extraction, which helps recover data from some broken Android devices. I have ever used the tool and it successfully retrieved my data from the Samsung S6 with a broken screen.
However, you'd better check the supporting list first if you are interested in it, as it just supports certain models.
SOURCE: HP Pavilion notebook's screen is too dark to see!
do u have a external monitor,connect it up and see whether,u r output is any better..
SOURCE: my tv screen is so dark can barely see anything
It is the inverter boards on the LCD panel that are bad. The inverters are what light up the LCD panel. The only way to fix it is to replace the inverter boards but usually they are not available by themselves and only come with the LCD panel.
SOURCE: impossible to change channels, turn TV on, Power and Opc blinking
go into programming mode and search for channels it will do this automatically to find all antennae and all cable channels if this is hooked up to a receiver box then only channel 3 will be found or used also most tvs are computerized these days and at times it will need to 'rebooted' unplug the power and wait 10 seconds and plug it in again this may have to be done whenever you are locked out from changing channels or using the volume controls
SOURCE: Heard loud pop, screen went dark. Audio still
I think your TV is DLP, if so replace the Lamp Call Encompass Parts 1-800-638-3328
