Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: Mitsubishi WD-62627 TV HD Problem: Has
Sounds like you are describing the Solorized Picture problem. This is a common problem on your model. Mitsubishi recommends removing and re-seating the DVI cable between the light engine and the chassis. If this doesn't fix it then you have to change the light engine. I have never seen a remove/reseat fix the problem myself but i have had a tech or 2 that i know fix it this way on occasion. Most of the time its a bad optical. Mitsubishi has extended the warranty for this problem on the 73" tv's but I do not think they are covering it on the 62" sets. If you are interested in going further on your own without a repairman let me know so i can assist.
Thank you
Tim
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
SOURCE: Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
SOURCE: color
i have the original color wheel in stock please email me if you need one - fyi its not hard to change
