SOURCE: My Zen Mozaic 8GB does not turn on.
I had the same problem, you have probably already tried this but I pressed the reset button (felt like a right plonker, but it did work) I just forgot it waas there!
SOURCE: need software for mozaic lx
you dont any software
just open the files in your zen and try iht like that
but if you do want the link to iht;;
http://www.creative.com/getstarted/zenmozaic/
SOURCE: cant import video
You need the software for the Mozaic. Most Creative brand players need the software it came bundled with to convert videos before it can added to the player.
If you don't have the Centrale software CD to convert videos, you can download it from Creative's site here:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic.
Choose the "Applications" section on this page, you want the Creative Zen Mozaic Starter Pack.
SOURCE: i dont know how to put tv shows onto my mozaic zen player
YES YOU DO YOU HAVE TO BACK TO STORE THE PLACE WHERE BROUGHT IT GO TO COSTUMER SERVICE AND ASK THEM OK SEXY
SOURCE: need a manual or instructions how to operate it
experimental status
ZEN mozaic player 2 GB
firmware 1.03
ZEN attached to USB 2.0
Windows XP SP2
Message "do not disconnect"
ZEN is not being recognized
Check ZEN memory setting
Memory ZEN is set to 0 in MENU>Etras>removable disk
Memory ZEN should be changed to maximum 1.5 GB
ZEN is recognized now
ZEN is ready to do the format command
ZEN can be written to for a maximum of 0.5 GB [internal memory !]
ALERT ! This 0.5 GB is the internal memory
The files written to the internal memory will be erased after
disconnecting !
access status
NO ACCES TO MY ZEN ?
1) Get access to ZEN by setting disk memory to maximum
2) ZEN should be recognized now
format status
1) FORMAT the disk
After formatting !
SET BACK YOUR disk memory capacity to zero [ 0 ]
for fully recovering the disk capacity
files presence status
FILES NOT PRESENT AFTER DISCONNECTING ?
- When set to zero you can use the full memory for
writing files to the player !
- When keeping the memory set to maximum you're using
the internal memory and written files are not saved
after disconnecting
updating + files presence status
UPDATING FIRMWARE ZEN MOZAIC = MAKING STANDARD MAPS
1) download the firmware that is suited for your computer
Operating System and your type of player from "CREATIVE"
2) Connect player to USB 2.0
and update with the firmware-update
3) Wait until the update is fully completed
4) After the update disconnect the player
5) Connect to USB 2.0 again
6) Check for the presence of the STANDARD MAPS for Music,
Pictures and Video
7) Files can be written into the STANDARD MAPS
8) Written files should be present after disconnecting
9) Files ready for mobile playing on ZEN mozaic now
CREATIVE support site for fimware / software / userguide
SUPPORT FOR ZEN MOZAIC ON THE INTERNET
