Serial number: 82559520
Production year: 12 September 1989 (serial nr.: 520) (Manufactured if Electric: Nashville or Memphis. if Acoustic: Bozeman, Montana.)
Not that important except for selling the bike, but if you really need to know then Google "Trek serial number" or "Trek 8000". Not possible to ID with just serial number. For more info see my T How to determine the year value etc of your bicycle
Impossible to ID most bikes by serial number alone, let alone assign a value without knowing condition, amount of original parts, etc. Do a little work yourself - Google "(brand/model) serial number" (without quotes) or at least tell us what kind of bike it is. See my tip: How to determine the year value etc of your bicycle
Not possible from serial number alone, and you may want to know the make but you don't really need to. Without original decals it's not valuable and parts are not brand specific. How to determine the year value etc of your bicycle
will need a micrometer, valve clearance adjustment tool set for shimmed lifters,small magnetic arm, appropriate shim selecting charts (manufacturer will have this if you can get the nec. measurements).
Measure thickness of shims removed (using micrometer) and use this formula where T=Thickness of old shim; A=Valve clearance measured; N=Thickness of new shim required.
Intake valves: N = T + (A - 0.02 mm (0.008 in.)) Exh. valves: N = T + (A - 0.25 mm (0.010 in.))
Then you need to find shims as close as possible to the calculated values.
Valve clearances (cold) are as follows: Intake0.15 - 0.25 mm (0.006 - 0.010 in.) Exhaust0.20 - 0.30 mm (0.008 - 0.012 in.)
Note, if you are not familiar with precision measuring using a micrometer, this may be better left to a trained tech. These are high revving little power plants and you don't want a problem at 8K rpm.
Here is a good place to look for your piano by make & serial number.
There are times when your piano name or number is not listed. They can help you find the year your piano was manufactured in most cases. Since you have the name & serial they should be able to answer your question. About the value... they can't possible know without seeing the piano. http://www.bluebookofpianos.com/serial1.htm
these days second hand photo camera's with film, are not worth much. Some younger persons (really only a few) would like to try these camera's for a while, but they don't pay much. Not knowing what lenses you have it is impossible to guess what their value can be. A 50 mm f 1,2 would bring more than a f 2 or even a 2,8.
Then before you could put it on ebay, you should at least shoot one film, to see if the camera still works.
Lately I bought a Nikon F90 and a F50 with a zoom lens and one was 30 dollar the one with the zoom was 20 dollar. both are in excellent condition, making fine photos with different lenses.
You could try checking on ebay, what they ask for a camera like yours, but perhaps you won;t even find one.
