20 Most Recent
Blackburn Flea Rear Flasher Bicycle Taillight Questions & Answers
I cannot get Blackburn flea to take a charge
It might be stuck in 'display mode' (described on the package). Try holding down the button for twenty seconds until you see the signal. Then try turning it on normally again.
How do i charge a Blackburn flea with a battery?
When I scratch around my cats spine, he immediatly starts licking the air. As my vet said, this is obvious sign of a flea allergy. Advantix multi was the solution, as two days later, and for the entire ...
Blackburn flea faulty
My Flea showed a steady red glow while mounted on the USB charger. When I took it off, it now ill not work. Any ideas?
After charging the Blackburn Rear Light, it won't
Your Flea iscontinuing to flash because it acquired extra energy during the charge. Once the extra energy has been burned it will shut off. To help preventthis try to charge the Flea for no longer than an hour to an hour and a half,and don't charge the Flea after every use.
I cant stop my flea
Hi.
The Flea can be in demo mode. Press and hold the power button for 30 seconds to reset the Flea. If that does not fix the problem, then the board inside the Flea can be defective. In that case contact Blackburn. Your Flea is warranted for life and will be replaced for free by the manufacturer.
Here support page.Before contacting Blackburn, try first holding down the button. The Flea is probably in demo mode.
Regards.
Ginko
My Flea Taillight won't charge
Try cleaning the contacts with a cotton swab and som isopropyl alcohol.
Let those dry.
Use a paper clip, or other small pointy object to clear the area around the contact points on the light so the recharger can fully "snap" into place.
Attach a battery you know has a good charge.
Turn on the light.
Did the light turn on?
If so, great, turn it off, and if it is blinking, let it recharge.
If it didn't turn on, isn't blinking and won't hold a charge after this process, return it to Blackburn and enjoy the benefits of your lifetime warranty.
I have lost my Blackburn Flea USB charging unit- anyone know where I can purchase one?
Is this what your looking for?
https://www.google.com/shopping/product/12301987183486171589?q=Blackburn+Flea+USB+charging+unit&prds=epd:17141075250351039146,prmr:3,tpim:CJem8L_LxP7BOxD3j_uT-d_8zTsYgJL0ASIDVVNEKM_4qO4FMNX-tQQ,pdprs:5,cs:1&utm_medium=tu_cu&utm_source=tu&utm_content=eid-lsjeuxoeqt&utm_campaign=9273173&gclid=CjwKCAjw0vTtBRBREiwA3URt7jEa4mdvgRgPco6AaPt6hWE37ss64trHXi6l7kweolhAhkkAgvwbnRoCBEwQAvD_BwE
11/3/2019 1:29:00 AM •
Blackburn...
Answered
on Nov 03, 2019
