SOURCE: maytag washer door boot
Remove 2 screws holding door hinge to cabinet and remove door. Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward. Remove panel from lower clips. At top of exposed area remove 2 5/16 screws. Remove brackets under them.
Open dispenser and remove 4 screws. Careful not to drop in dispenser. Remove dispenser frame assembly.
You can now raise top of washer to a 90 degree position.
Now back to front exposed area. Grab boot where it contacts front and peel out of groove. Also remove two screws holding light assembly and remove cover. Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel. Remove front assembly by folding up and onto top.
Now we are at the boot. Remove spring and wire assembly holding boot to drum. Make note on boot position and spring position. Remove boot. Install new boot onto drum. wrap wire around drum with ends at top. Now the fun! Hook spring to on end of wire and using vise-grips, pull to other end to hook into wire. It can be done, honest.
Now just reverse to reassemble. should be instructions with boot. Good luck!
SOURCE: Maytag neptune dryer won't start
Hey all neptune stricken owners - I removed the circuit board which was darkened substantially in the resistor area, but the maytag repairman got no money this time!! . . . And the cold is no longer the problem it has been for the past couple of years. We replaced the 3 main capacitors(blue) and the cluster of four resistors(brown) - and voila - the dryer works like new!!! It only cost a few bucks ($.67, $.92 etc etc) as opposed to the $151 a new board was going to cost!
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
SOURCE: how to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
SOURCE: neptune tl washing machine spin cycle
Mother26, I have a fair amount of experience with mechanics and have repaired a few washing machines and dryers in my past. For me, both components are easy to replace. Your repairman would have an equally easy time. I'd estimate an hour to repair and verify. Your trouble comes in is the $122 for the replacement clutch and the $82 for the tub displacement sensor. And that's assuming there's no damage to anything else so far.
In my case, change the previous owner didn't remove from pockets destroyed the clutch, transmission, and pump. and somehow spillage caused the tub displacement sensor to short. Overall, far too many parts to make repair equitable.
Keep in mind, this is, in the opinion of many, a failed design on the part of Maytag. Ultimately, it's a toss up on how confident you are that your current condition is the limit of your problems.
