Ovens Logo
J
Jeff Jones Posted on Jan 11, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heating elements for kenmore electric oven, moodel 790.9270220132
Richard C Cohen
Level 2:
  • Expert 171 Answers
  • Posted on Jan 24, 2020
Richard C Cohen
Expert
Level 2:
Answers
171
Questions
Helped
78367
Points
427
Hello. The closest model to the one you say you have is
79092702011... There is nothing on the sears website remotely close...The elements, if this is the real model you have, are as follows:
bake...316505500
Broil...316203301
I hope this helps you...
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Apr 16, 2007
SOURCE: electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
Anonymous
  • 288 Answers
  • Posted on Jan 13, 2008
SOURCE: no heat in either oven
May I please have some more information. How do you know you have electricity, because the display is on, inside lights etc. Have you checked the voltage from the wall? It is possible on 220v appliances that 1/2 of the breaker has tripped, thus all the 110v systems work (like lights) except the heating elements, which are 220v. Because both ovens have the same problem, its most likely a power source problem.
Anonymous
  • 161 Answers
  • Posted on Jul 15, 2008
SOURCE: Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Anonymous
  • 213 Answers
  • Posted on Jan 07, 2010
SOURCE: oven's bottom heating element does not heat
this should show you how to change it
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
The main fault when the oven is not heating is that the element has blown here is a video on how to change your fan oven element and the motor.
For all your fan oven element click here
ashburton
  • 417 Answers
  • Posted on Jan 15, 2010
SOURCE: Need to replace heating element
Have you tried www.appliancepartspros.com
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Kenmore electric range oven baking element does not go on eveything else works
The bake element
2answers
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
3helpful
2answers
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
1helpful
Kenmore oven door locked need help
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
1helpful
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
1helpful
Kenmore Range 911.9324890
Replace recepticles for large elements. It is the part that the heating elements go into. And while you are at the appliance store, pickup a new bake element for your oven. Just unscrew element from oven wall and install new one.
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
