Remote control code
Hi
Here is the link for all Codes
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
and the Manual for instructions
http://www.remotecodelist.com/remotes/ge/RM24912_instructions.pdf
Good Luck
SOY DE PUERTO RICO COMPRE UN CONTROL UNIVERSAL POR EL DE MI TV SE DAñO PERO NO APARECE LA MARCA DE MI TV Q ES TCL POR FAVOR SI LO TIENEN EL CODE ME AVIDAN PORM FAVOR
MI EMAIL ES
[email protected]
SOURCE: philips pm 335 universal control
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
SOURCE: small universal remote control 'TOTAL control' brand
I downloaded the complete user manual for free at Forum: www.remotecentral.com
SOURCE: i need the 3-digit code for my sharp tv code
Here is a link to an extensive list for your 3 digit code to use with Chunghop
preprogrammed remote controls it includes scanned copies of 6 different
versions, plus a cross-reference chart. I hope this helps, if it does please let me know by giving me a yes helpful rating~
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=chunghop&dv=universalremote&md=chunghop3digitcodescollection&kw=&st=&ar=&dt=&so=&pg=1&file=others/chunghop/chunghop-3digit.zip
