There is a website >>> https://routerunlock.com/simlock/lg/lg-cosmos-2/ <<
This has instructions to unlock your device.
Regards
Geoff
SOURCE: How do u reset the lock code on the lg 8500 chocolate
Dial #4357*4357 and that should give you the phone information including the phone number.
SOURCE: my samsung f480 mobile is locked up dont know the password to it
okay its more than likely 0000 or the last digits of the cell number give that a try
SOURCE: Forgot my LG keybo's lock code
well usually the default code is the last 4 digits of your number, but being that you changed it, there isnt much you can do except go back to the store and have them do it.
SOURCE: Call barring password
it is 0000 for sure by default
and if it is changed just restore the cell to factory setting
SOURCE: manuelly programming lg vx 9900 to cricket service
any missing info should be provided by your reseller.......
here is what I found...
Note: Some Programming must be done from the internal keypad / QWERTY Keyboard.
Alternate Programming Sequence for the VX9900 (Orange) or for newer software versions.
[#] [#] + [7][7][6][4][7][2][6][9][9][0][0] + [SEND]
OTA PROGRAMMING
Step 01:
Change ESN in billing system.
Step 02:
Power up the handset.
Step 03:
Dial *228 + SEND
Step 04:
Follow the VRU prompts
USE OTA Where Available. If OTA is not available follow instructions below.
Top
AKEY PROGRAMMING
Step 01:
Generate a random A-Key and power phone on.
Step 02:
With the flip CLOSED, press 2539 + * + * to access AKEY INPUT MODE.
Step 03:
Press 1 for Akey Entry
Step 04:
New AKEY displays, enter 26 digit A-key then press OK when complete.
PROGRAMMING COMPLETE
Try calling either #228 or i think its *228 and re-programming your phone, it will change the lock code to its default, he last 4 digits of your number without changing anything else
