20 Most Recent
LG KP501 Cell Phone Questions & Answers
My lgkp501 won't switch on lg screen comes up but
FREEZING OF PHONE
Hi, when a phone randomly freezes, it means that the phones memory is faulty or when an application you downloaded has virus.
What to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
How do i unlock?
You'll need to purchase an unlock code.You will probably find a number of companies via google a I have used a couple, which I'm not sure I'm allowed to post here so I recommend you visit
Unlock-Zone.com, which is nearly perfect and they were recommended highly in the cell phone forums.Click the unlock your phone and select the mobile phone, current service provider to get the available unlocking service which ranges from $5 to about $25, depending on the model of phone you have.
Lg kp501
sounds like you need more memory try a larger memory card
Setting wallpapers
Ghassan, first check your memory status of device (not memory card), maybe your device has not enough memory due to your saved data, first delete some not important data. and check it will not say this message.if my suggestion was helpful please rate it.Thanks visiting Fixya.com
How do I unlock my lg kp501 mobile from orange
There are many ways to unlock your LG mobile.But i suggest codes which is safe method of unlocking. You can get the unlocking service for your LG mobile from your network provider.After getting your code, you may follow the instructions at
Mobileunlockguide.com .This will help you to unlock your mobile easily.
Unlock lg kp501
You can unlock your LG kp501 mobile from network lock using unlock code...Once you unlocked it you can use any gsm network sim card in your mobile at any country...I found an unlocking service at here
www.unlocking4u.com and unlocked my mobile successfully.This is the online service which offer the code at reasonable cost...Through this can unlock your mobile easily...
