SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me:
Our KitchenAid KUDP series dishwasher went into a mode where it would
not start and would only respond to the cancel/drain button. The clean
light would flash 7 times in a row, stop, and then repeat. I read that
the 7 flashes indicates an error code and that the dishwasher has
detected a problem in the heater element circuit. I tried to reset the
error mode by turning off power for 15 minutes, however, that did not
work.
We
called for a repair. The service person found that the dishwasher was
completely fine except that it had gone into an error mode. The
technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We
were told the dishwasher expects to see the dish water temperature rise
in a certain way. If the water does not heat in this way, the
dishwasher becomes confused and thinks the heater element has failed.
In deed, this happened just following and extended power failure and
our hot water tank was cool. I am curious if this code will work for
anybody else with the same problem and save a service call and 115
bucks. Overall, this seems to be a serious logic flaw in the design.
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
SOURCE: I have a Kitchen Aid
Hello Lisa. Go to your electrical panel for your home or apartment and turn off the circuit to the dishwasher for two full minutes. Check to be sure that you have turned off the correct circuit by looking to see that the "clean" light is off. After two full minutes turn the circuit back on. This alone may reset the machine and the control panel.
If it does not, then you will have a decision to making regarding repair VS replace. I always make this recommendation to my customers with any appliance over 5 years old. Replace it. In this instance, the new dishwashers use much less water, much less electricity, are much quieter, and they do a much better job. The advancements in dishwasher technology and design have been remarkable in the past three years. Joe
