I fixed this error by changing two capacitors(C2 and C3) on IHPU board see link witth foto below:
https://konicavod.3bb.ru/viewtopic.php?id=512
Error message and link to service manual at the link below might be of assistance.
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20554e&code=C3B07
https://printcopy.info/?mod=srch&inmod=docs&brand=Konica-Minolta&strSearch=bizhub+554e
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: error code F-35-1 in bizhub 7145 copier
quote is probably in the right price range. you need to look at how many copies are on your machine. look at any future repairs/supplies that will be needed. like drum, developer unit. If these are also needing to be changed soon, you will have to plan on those costs also. Any comparable machine that you get get will be expensive to repair the big items. You have to put all of the money that you spent on the machine and find out how many copies you have made. you can then figure out the cost per copy. At the same time, if this machine does everything that you need from a copier, do you want to buy a new one at much higher cost.
SOURCE: How to fix Error Code C3901 on a Minolta Bizhub
Enter service mode & Clear All
Utility>Stop>0>0>Stop>0>1
All of this within 3 secs.
Please Rate me.
SOURCE: Our KonicaMinolta Bizhub C280 Internal Error C2555
You didn't mention the size of the job size, but it sounds like a memory problem. If you have a service contract or it's still under warranty, contact your rep before you start opening things up.
The following is if you don't have a service contract. If the bizhub has been working with no problems in the past, try reseating or replacing the RAM. I've had to replace RAM that started causing problems on classroom computers. If you bought it refurbished (used) check to see the 2GB RAM that supposed to come with the bizhub hasn't been removed or replaced with smaller memory.
SOURCE: How to make nvram recovery
You'll need:
1- 1 compatible CompactFlash card (not all of them work, you'll need to try for yourself)
1- 1 CompactFlash card reader/writer
1- This tool
There should be a document enclosed with that tool explaining the process, it's fairly easy and quick. Notice that the procedure will solve some NVRAM related problems and also some network card related problems, but it will not erase your counters.
