Cameras Logo
I
Ion Grove-White Posted on Nov 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba tv 43u2963db
Find settings menu
Tony Parsons
Level 3:
  • Toshiba Master 6,405 Answers
  • Posted on Nov 30, 2019
Tony Parsons
Toshiba Master
Level 3:
Answers
6405
Questions
Helped
1652384
Points
20272
A) This is not a camera
b) Have you looked in the manual ?
How can you get to the menu on a Toshiba tv without a remote
If you do not have a remote for your Toshiba TV, there are a few ways you can access the menu to change settings or perform other functions:
  1. Use the buttons on the TV: Some Toshiba TVs have buttons on the side or back of the TV that can be used to access the menu or perform other functions. Check the TV's manual or the label on the back of the TV to see if this is the case for your TV and which buttons to use.
  2. Use a universal remote: You can purchase a universal remote that is compatible with your Toshiba TV. These remotes can be programmed to control your TV, and can be used to access the menu and other functions.
  3. Connect a keyboard or mouse to the TV: If your TV has a USB port, you can connect a keyboard or mouse to the TV and use it to navigate the menu and other functions.
  4. Use a mobile app: Some Toshiba TVs can be controlled using a mobile app that can be downloaded to your smartphone or tablet. This app allows you to control your TV and access the menu without needing a remote.
Changing language on Toshiba 32W24 TV from russian to english
How to Change Toshiba TV Language to English
Since the TV has been set in a foreign language, you might have trouble identifying what's written on your TV. In that case, you might have to take a note of the type and number of keys pressed in the below steps.
  1. On your Toshiba TV's remote, press the Menu button.
  2. Then press the Menu buttons on your remote two times. This will take you to the Settings page.
  3. Press the OK button your remote to confirm your selection.
  4. Now tap the Down button on your remote once to go to the Language menu and press the OK button.
  5. The first option will be the language selection menu and that will be selected by default.
  6. So just use the "Left" or "Right" button on your TV remote to English (or any other language of your choice).
  7. You may now hit the Exit button on your remote to close the Settings option.
2answers
I need a pin code for a Toshiba tv. Please
hi Cheryl.
Press the "MENU" button, select Prefer, highlight Parental Control and press the right arrow key or menu button to enter the PIN code entry screen. 0000 is the default password. When the correct PIN # is entered the Parental Control Menu opens and you can change your settings and PIN code here.
Changing the TV password
or read up some more at this manual.
Toshiba 19L4200U User Manual Forgotten Pin Code Changing Or Deleting Your...
or this one.
4 digit pin code for toshiba tv Google Search
1helpful
2answers
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
The drop down menu seems to be permanately down. tv works behind
http://tv.manualsonline.com/search.html?q=Toshiba+36A43&submit.x=45&submit.y=12
scroll down to middle of page for the free manual which should help you the most but you might have a small reset button on the back which will set the setting back to defualt. or in the manual it will tell you how to set it back to defualt factory settings
TOSHIBA MODEL MV13M2 NO MANUAL, NO FACTORY REMOTE
HI
Yes you can set the menu function if have menu button is there!
Thanks!
CANNOT SET UP MENU ON TOSHIBA TDS_RDXV$*
Young lad next door showed hubby how to set menu up . Then noticed only HDMI cable NO scart lead for VCR did that as well. Thanks for getting back .
8helpful
2answers
Toshiba code for remote for direct tv
Try these remote codes
Toshiba 018, 021, 023, 071, 085, 090
, 0154 , 0156 ,0060
Toshiba 36a40
Your set is  in demo mode---your owners manual will help----
 Try holding Menu & power on (front of set) four seconds or
 maybe vol up & channel up at same time......T.
Top Toshiba Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
