SOURCE: No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
SOURCE: Fuhifilm finepix a700
Can you play back pictures and is the quality of these ok ? If you can but there is no image in capture mode then the CCD sensor is faulty and needs replacing.
SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
SOURCE: Stopped taking pictures
How old is the film in camera & when did you put in the film?
Polaroid's battery is built in with the film package.
If the package is old or been in the camera for a long time battery may be low or dead.
Try changing film out.
Good Luck! Hope this helped. Please rate.
MSG back if you need more help.
