SOURCE: Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
SOURCE: toilet sounds like it is flushed or water filling up in the tank.
if the toilet has a 'flapper' is there slack in the chain connecting it to the flush arm? The flapper life is usually around 4 years or so - replace it if older.
SOURCE: Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
SOURCE: toilet keeps filling tank every 10 minutes
If there is no water on the floor then the water is leaking down the main tank drain. Take off the tank lid, turn off the water supply to the toilet. Fllush as much water out as you can. Look at the main drain, sometimes if the flapper valve is connected with a chain, the chain can get caught between the flapper valve and the drain hole, the flapper valve is pliable so it tries to seal around the obstruction but can't always do it. Make sure there is obstruction, that the flapper valve is not out of shape or old and non-pliable and that it lines up with the drain hole and doesn't get "hung up" on anything.
SOURCE: My Toto Drake toilet makes a noise like it is gasping for air
just simply clean the auto switch,the noosle where the water comes out when the floater goes down everytime the tank is empty with water.
