SOURCE: Will not stay on
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
SOURCE: my e2 frozen on the palm powered logo
Okay here it goes, your going to want to leave it on for however many hours it takes to completely drain the battery then you're going to want to recharge it back to normal charge, and try restarting it again. This will delete completely anything that is keeping it from restarting properly. If you did open up the machine without following "antistatic procedure" you may have fried a component on the board and then your in trouble
you'll need to salvage a board from another tungsten and put it back in your PDA and hope you put it back together right
SOURCE: hi please help me with my acer 3003 wont boot
try to power up with power cord only and see if it works. If no lights turn on than your motherboard is dead. If it turns on and nothing happens make sure there is memory installed(RAM). If it turns on and you see windows screen than it shuts off than your operating system needs to be installed again. Also, you can try booting in safe mode by hitting f8 when you initially start your computer and see if it stays on and if it does you have a virus most likely. Good luck.
SOURCE: palm centro will not power up
hey i got a same problem too.......i think our software is gone. we need a new os.thank u
You can return the phone to its factory settings
and remove all of the programmes and data you
have added by resetting the system.
Performing a soft reset
If your phone responds slowly, stops
responding, or freezes, try a soft reset. A soft
reset causes the phone to restart and re-adjust
memory allocation. Unsaved data in open
windows may be lost.
To perform a soft reset:
Press the RESET key inside the hole on the right
of the phone with your stylus pen.
Performing a hard reset
To perform a hard reset:
Follow the soft reset procedure on the previous
section while also sliding the Power key down
and holding.
Resetting the phone
To reset the phone's system:
From the Start menu, tap Settings ? System
tab ? Clear Memory ? Clear Memory. Write
"yes" in the input field and tap Yes.
After about 5 seconds, the phone reboots and
then begins alignment process.
RESET key
inside the hole
WARNING!
Resetting will delete all your programmes and
data you have added.
