You can return the phone to its factory settings
and remove all of the programmes and data you
have added by resetting the system.
Performing a soft reset
If your phone responds slowly, stops
responding, or freezes, try a soft reset. A soft
reset causes the phone to restart and re-adjust
memory allocation. Unsaved data in open
windows may be lost.
To perform a soft reset:
Press the RESET key inside the hole on the right
of the phone with your stylus pen.
Performing a hard reset
To perform a hard reset:
Follow the soft reset procedure on the previous
section while also sliding the Power key down
and holding.
Resetting the phone
To reset the phone's system:
From the Start menu, tap Settings ? System
tab ? Clear Memory ? Clear Memory. Write
"yes" in the input field and tap Yes.
After about 5 seconds, the phone reboots and
then begins alignment process.
RESET key
inside the hole
WARNING!
Resetting will delete all your programmes and
data you have added.
29 questions posted
736 Questions
430 Questions
332 Questions
330 Questions
306 Questions
