Wireless EPSON Printer issues Troubleshooting 1+8OO8O3-IO69 EPSON wireless printer? A range of common wireless printing problems can impact your EPSON Printer connectivity such as: 1 Can't connect to EPSON wireless printer 2 Can't find EPSON wireless printer on network 3 Flashing blue light on the wireless EPSON Printer 4 Error printing from EPSON wireless printer 5 Error setting up the wireless EPSON Printer If Problem Persists Call Us At 1+8OO8O3-IO69 Troubleshooting Uninstall and reinstall the EPSON Printer driver and software . Some EPSON software components might have installed incorrectly, even if the EPSON Printer setup failed. Remove and reinstall the software to clear any possible issues. 1 Disconnect the USB cable from the printer, if necessary. 2 In Windows, search for and open Control Panel. 3 Under Programs or Programs and Features, click Uninstall a program to open the list of installed programs. 4 Click the EPSON printer name to open the uninstall confirmation window, and then click Yes to complete the software removal. 5 Make sure the printer is turned on, cartridges are installed, and plain paper is loaded in the main tray. 6 Go to EPSON Software & Driver Download, type your printer model and follow the instructions to download and install the driver. 7 During the installation, select the full software option to get the most out of your EPSON printer, and then follow the steps to set up the printer connection. Try to print. If the issue is not resolved, call us at 1+8OO8O3-IO69
SOURCE: searching drivers for sharp AR-5316 for windows Vista platform.
are you sure it is for a Vista or is it trying to load to a Windows based OS???
try this site
http://promosearch.sharpusa.com/search/?sp-q=ar%205316%20drivers&sp-a=sp10009e61&sp-k=
Personally I do not like their site it is not as user friendly as other sites. ( have to do a lot of research to find what you want)
Good luck
SOURCE: Try to print but: get General Printer error 0x61000f6 beware spam number 1*800*532*4187
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Testimonial: "Thank you very much for the information. very helpful. I am sure this information will help other people as well. Thanks again. "
SOURCE: Cannot install HP Deskjet 3745
Open the Devices and Printers folder
Right click on the Printer icon and Click on Troubleshoot
Follow the instructions and finish the Troubleshooter Wizard
You should be able to print
