Check the audio settings on the PC, sometimes different inputs require different settings. There should be input setting alternatives in the audio section in the control panel on your PC.
Thanks Steve, very helpful
If using Win 10 and especially with a Dell, restart your PC with the trntbl powered on and connected to your PC. 9.974% of the time. hopefully you will fall into the higher side of the odds. lol. It's a driver issue they can't seem to correct in Windows.
SOURCE: Speakers work...just not when plugged into desktop
If you need some help troubleshooting your sound card post its manufacturer and model number, or if its built-into your motherboard its manuf and model number. The manufacturer and model of the PC in addition to your operating system would help as well.
SOURCE: turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
My gateway 2000 speakers don't have sound coming from them
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
SOURCE: i PURCHASED A LIKE NEW TECHNICS SL BD27 TURNTABLE.
Yes you need a pre amp
It would also be the same if you connected it to a computer to record an LP to CD. Mine is a little different and has one already built in that I can switch in and out of line.
Try spend a little more if you can as many pre amps can introduce noise.
You may also want to check that the turntable is properly grounded to prevent noise too
Testimonial: "VERY FAST RESPONSE. THANKS"
